Radiobar
thank you for the quick response. I was told that there was never a radio in it. I have looked for mounting screw holes and cannot see any. I will take more detailed photos and send later this afternoon (west coast time).  Odd thing is that the "Radiobar CO. of America" nameplate does not even have patent numbers listed on it, weird. More to follow later today.
Radiobar - by Johnboy17 - 08-24-2018, 10:41 AM
RE: Radiobar - by Nathan Slingerland - 08-24-2018, 11:05 AM
RE: Radiobar - by wardmc1 - 08-24-2018, 11:21 AM
RE: Radiobar - by Johnboy17 - 08-24-2018, 11:23 AM
RE: Radiobar - by Johnboy17 - 08-24-2018, 11:27 AM
RE: Radiobar - by wardmc1 - 08-24-2018, 12:28 PM
RE: Radiobar - by Johnboy17 - 08-24-2018, 12:33 PM
RE: Radiobar - by OldRestorer - 08-29-2018, 10:27 AM
There are currently 8069 online users. [Complete List]
» 1 Member(s) | 8068 Guest(s)
