Trying to Restore 48-472 code 122
Per the schematic, loop only has two connections, those will measure a low resistance when checked with a ohm meter. Third is for FM, should be easy to sort out.
Tom
Trying to Restore 48-472 code 122 - by apERNA1985 - 08-19-2018, 10:49 PM
RE: Trying to Restore 48-472 code 122 - by KCMike - 08-20-2018, 10:11 AM
RE: Trying to Restore 48-472 code 122 - by KCMike - 08-20-2018, 10:17 AM
RE: Trying to Restore 48-472 code 122 - by 35Z5 - 08-22-2018, 05:37 PM
RE: Trying to Restore 48-472 code 122 - by 35Z5 - 08-25-2018, 12:07 AM
RE: Trying to Restore 48-472 code 122 - by 35Z5 - 08-26-2018, 10:03 AM
91H Code 126 Restore
There are currently 2976 online users. [Complete List]
» 1 Member(s) | 2975 Guest(s)
