Zenith 10A1
Should be a good performing 1940 radio. Has built in wavemagnet Antenna and an RF stage. You are right that it has the dual 6X5 rectifier arrangement, but that can be dealt with. Just beware it might have rubber wiring, but don’t let the scare you. Just don’t power up till recapped and serviced.
http://www.nostalgiaair.org/pagesbymodel...024676.pdf
Tony
Zenith 10A1 - by rfeenstra - 08-27-2018, 10:16 PM
RE: Zenith 10A1 - by morzh - 08-27-2018, 10:27 PM
RE: Zenith 10A1 - by Paul Philco322 - 08-27-2018, 10:33 PM
RE: Zenith 10A1 - by tbone - 08-28-2018, 06:04 AM
RE: Zenith 10A1 - by Chas - 08-28-2018, 11:00 AM
RE: Zenith 10A1 - by rfeenstra - 08-28-2018, 10:18 PM
RE: Zenith 10A1 - by Arran - 08-29-2018, 02:39 AM
RE: Zenith 10A1 - by Eliot Ness - 08-29-2018, 07:48 AM
There are currently 9001 online users. [Complete List]
» 2 Member(s) | 8999 Guest(s)
