Zenith 10A1
Arran is correct, 10A1 is the chassis # and according to the Zenith service manual it was used in 4 different cabinets:
https://www.radiomuseum.org/r/zenith_10s...h10a1.html
Zenith 10A1 - by rfeenstra - 08-27-2018, 10:16 PM
RE: Zenith 10A1 - by morzh - 08-27-2018, 10:27 PM
RE: Zenith 10A1 - by Paul Philco322 - 08-27-2018, 10:33 PM
RE: Zenith 10A1 - by tbone - 08-28-2018, 06:04 AM
RE: Zenith 10A1 - by Chas - 08-28-2018, 11:00 AM
RE: Zenith 10A1 - by rfeenstra - 08-28-2018, 10:18 PM
RE: Zenith 10A1 - by Arran - 08-29-2018, 02:39 AM
RE: Zenith 10A1 - by Eliot Ness - 08-29-2018, 07:48 AM
There are currently 10262 online users. [Complete List]
» 3 Member(s) | 10259 Guest(s)
