New to Forum- 47-1230 is my 1st Restoration
So what is the resistance btw C-103 - and chassis ground??
You need the -16v to bias the output tubes (6V6's) w/o it they will draw a fair amount of plate current.
Pull out the two 6V6's and see if your HV is about where it should be.
RE: New to Forum- 47-1230 is my 1st Restoration - by Radioroslyn - 08-30-2018, 05:54 PM
91H Code 126 Restore
