Where do I find the chassis number...46-1201
Working on what I think was a 46-1201 and have read there is a 48-1201 which looks the same other than electrical changes.
Where do I find what model and code chassis I have?
I am looking at re-capping and there have been caps replaced over the years.
The chassis I have has two separate 40 mfd caps but have not seen a schematic that shows these. They look original.
Tube line up is 7A8, 7B7, 50Y6, 50L6 and 7C6.
Thanks for any info.
Brian
Where do I find the chassis number...46-1201 - by Guest - 08-16-2010, 03:34 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
