6287-R Block condensor
Another question on this are the internal connections.  What lugs are these two 0.15 caps connected to?  This block is only specified as a single .25, but there are three lugs and all of them are used as a connection point for something.  There is no reference on the schematic of using a single cap inside this block.  Is the middle lug a dummy?  I do not see a wire coming up through the rivet on the middle lug, so maybe it is.
Are there any pre 1936 catalogs out there that have these discontinued blocks so I won't have to keep asking about their specs?
6287-R Block condensor - by Brian_w5ami - 08-31-2018, 12:51 PM
RE: 6287-R Block condensor - by Radioroslyn - 08-31-2018, 03:13 PM
RE: 6287-R Block condensor - by Brian_w5ami - 08-31-2018, 05:29 PM
RE: 6287-R Block condensor - by Brian_w5ami - 08-31-2018, 06:42 PM
RE: 6287-R Block condensor - by PhilcoPhan1936 - 08-31-2018, 08:43 PM
RE: 6287-R Block condensor - by Ron Ramirez - 09-01-2018, 12:58 PM
RE: 6287-R Block condensor - by Brian_w5ami - 09-01-2018, 01:04 PM
RE: 6287-R Block condensor - by PhilcoPhan1936 - 09-01-2018, 01:09 PM
RE: 6287-R Block condensor - by gary rabbitt - 10-11-2018, 11:35 PM
91H Code 126 Restore
