Ron's Cabinet Work for the 2018 Season
#35
Quote:Oddly enough, only the front panel appears to be conventional open grain walnut. The top and side panels appear to be some sort of more closed grain wood.
I have never worked on one of these , but most of the "Clyde Shuler" style cathedrals and the shouldered tombstones used fir plywood for the sides. They were toned dark to look like walnut.
M R Radios   C M Tubes
RE: Ron's Cabinet Work for the 2018 Season - by Steve Davis - 09-01-2018, 08:00 PM
