40-158 Veneer question- Updated-Finished!
That's tough problem to fix. General consensus is you can try gluing but most of the time it will reappear after a while. Diehards will remove the veneer which in your case is a pretty big piece. Sometimes the the wood under the veneer is cracking too so that may need to replaced also. If I was going to remove the veneer I would cut it between the two inlays.
I was recently gifted a very similar set (40-165K) at has an extra band and pushbuttons. I've been very happy w/the performance of the set. Good sounding and good sensitivity. This one was missing the spkr so I ended up fitting w/a 15" RCA pm job and an old junk box choke to replace the field coil. If you could use a couple of pics of the dial escutcheon I can post them. It's shrunk a little and a couple of the corners are missing but still presentable.
RE: 40-158 Veneer question - by Radioroslyn - 09-01-2018, 09:38 PM
RE: 40-158 Veneer question - by Greggshere - 09-01-2018, 09:53 PM
RE: 40-158 Veneer question - by Radioroslyn - 09-01-2018, 10:16 PM
RE: 40-158 Veneer question - by Greggshere - 09-01-2018, 10:41 PM
RE: 40-158 Veneer question - by Greggshere - 10-07-2018, 11:41 PM
RE: 40-158 Veneer question - by DadsRadio - 10-13-2018, 09:40 AM
RE: 40-158 Veneer question - by klondike98 - 10-13-2018, 07:18 PM
RE: 40-158 Veneer question - by DadsRadio - 10-15-2018, 07:29 PM
RE: 40-158 Veneer question - by Radioroslyn - 10-16-2018, 11:46 PM
RE: 40-158 Veneer question - by Greggshere - 10-17-2018, 12:19 AM
RE: 40-158 Veneer question - by Ron Ramirez - 10-17-2018, 05:56 AM
RE: 40-158 Veneer question - by Greggshere - 10-17-2018, 10:52 AM
RE: 40-158 Veneer question - by Ron Ramirez - 10-17-2018, 11:44 AM
RE: 40-158 Veneer question - by Greggshere - 10-17-2018, 12:51 PM
RE: 40-158 Veneer question - by Greggshere - 10-21-2018, 12:04 AM
RE: 40-158 Veneer question - by klondike98 - 10-21-2018, 09:32 AM
RE: 40-158 Veneer question - by DadsRadio - 10-25-2018, 01:57 PM
RE: 40-158 Veneer question - by Greggshere - 10-26-2018, 05:03 PM
