Ron's Cabinet Work for the 2018 Season
#39
Thanks Ed!
Most of this morning was spent masking off the 66B cabinet and the RCA 6T2 cabinet.
Here is the 66B before I began to spray the Mohawk black lacquer:
[Image: http://www.philcoradio.com/images/phorum...18_024.jpg]
After two coats of black:
[Image: http://www.philcoradio.com/images/phorum...18_025.jpg]
It turned out well, save for one little run on the trim whcih is at top center:
[Image: http://www.philcoradio.com/images/phorum...18_026.jpg]
I will try to correct that in a little while by carefully sanding the run, then (also carefully) reapplying more black lacquer to the area. All of this while the cabinet is still masked off.
RE: Ron's Cabinet Work for the 2018 Season - by Ron Ramirez - 09-03-2018, 12:55 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8146 online users. [Complete List]
» 1 Member(s) | 8145 Guest(s)
