crosley
You're probably looking for something around 2-5 Henrys @ 100ma if you wanted to use a choke to replace the field coil from the original spkr. If you use a power resistor I'd double up on the capacitance of the filters as you won't have any inductane in the resistor to smooth out the AC ripple.
Ps Hi how you making out?
crosley - by denver - 06-27-2010, 09:19 PM
Re: crosley - by Uffda - 06-28-2010, 04:14 PM
Re: crosley - by denver - 06-29-2010, 05:33 PM
Re: crosley - by denver - 06-29-2010, 05:50 PM
Re: crosley - by denver - 07-06-2010, 06:17 PM
Re: crosley - by Dave - 07-07-2010, 01:30 PM
Re: crosley - by denver - 07-07-2010, 02:10 PM
Re: crosley - by exray - 07-07-2010, 10:35 PM
Re: crosley - by 7estatdef - 08-19-2010, 07:49 AM
Re: crosley - by denver - 08-20-2010, 10:57 PM
