Signal generator trouble
We discussed this here before, some years ago. SS generators used with tube equipment should be protected either with a zener or a double diode to limit the voltage it can see. BTW the transformer might not help: it will reflect the voltage spike if it is 1:1.
Depending on the amplitude of the signal I would either use two diodes (in reverse-parallel) in parallel to the output after the capacitor, or a symmetrical Zener, also in parallel.
Signal generator trouble - by EdHolland - 09-04-2018, 04:18 PM
RE: Signal generator trouble - by Eliot Ness - 09-05-2018, 08:42 AM
RE: Signal generator trouble - by morzh - 09-05-2018, 09:27 AM
RE: Signal generator trouble - by EdHolland - 09-05-2018, 01:54 PM
RE: Signal generator trouble - by EdHolland - 09-07-2018, 12:29 AM
RE: Signal generator trouble - by EdHolland - 09-16-2018, 09:28 PM
