Help with 48-482
Found the problem! Z404, a choke/cap combination, was wired to the white lead on Z400 instead of the green lead. The two connection points are right next to each other. That caused a very weak signal from the plate of the converter. Connected it properly, aligned the IF, and picks up stations. I really think the stock speaker is too small for this radio.
Help with 48-482 - by Patrick - 09-03-2018, 10:08 AM
RE: Help with 48-482 - by morzh - 09-03-2018, 05:07 PM
RE: Help with 48-482 - by Patrick - 09-03-2018, 05:18 PM
RE: Help with 48-482 - by morzh - 09-03-2018, 05:23 PM
RE: Help with 48-482 - by Patrick - 09-03-2018, 05:37 PM
RE: Help with 48-482 - by Radioroslyn - 09-03-2018, 08:37 PM
RE: Help with 48-482 - by morzh - 09-03-2018, 08:59 PM
RE: Help with 48-482 - by Patrick - 09-03-2018, 09:23 PM
RE: Help with 48-482 - by Patrick - 09-03-2018, 09:25 PM
RE: Help with 48-482 - by mikethedruid - 09-04-2018, 01:40 AM
RE: Help with 48-482 - by Patrick - 09-04-2018, 05:46 AM
RE: Help with 48-482 - by morzh - 09-04-2018, 08:46 AM
RE: Help with 48-482 - by Patrick - 09-04-2018, 12:42 PM
RE: Help with 48-482 - by Patrick - 09-07-2018, 07:38 AM
91H Code 126 Restore
There are currently 4989 online users. [Complete List]
» 1 Member(s) | 4988 Guest(s)
