Westinghouse RA-DA
Brad;
  The RCA branded RA-DA, alternatively known as an RC unit, was branded for sale as such, however in the Canadian market Canadian Westinghouse also marketed and sold these under their own name, much like the Aeriola Seniors and the Radiolas III and IIIA. The latter were also made by Canadian G.E whom modified the design to accept UV 199 tubes as opposed to WD-11s. With regard to the RA-DA sets I think that they will work with 201As, at least in the amplifier section, the 200 and 200As were intended for use as detector tubes, I think Russ would know as he recently had one for sale.
Westinghouse RA-DA - by Brad Winder - 09-09-2018, 10:41 PM
RE: Westinghouse RA-DA - by Arran - 09-10-2018, 03:04 AM
RE: Westinghouse RA-DA - by Chas - 09-10-2018, 08:54 AM
RE: Westinghouse RA-DA - by Phlogiston - 09-10-2018, 04:03 PM
RE: Westinghouse RA-DA - by Brad Winder - 09-18-2018, 08:32 AM
RE: Westinghouse RA-DA - by Phlogiston - 09-18-2018, 12:34 PM
RE: Westinghouse RA-DA - by Arran - 09-18-2018, 03:36 PM
There are currently 8078 online users. [Complete List]
» 2 Member(s) | 8076 Guest(s)
