Westinghouse RA-DA
It will work with 1/4 amp tubes, though you will loose much of the filament control - so this must be done with your power supply.
The one I sold would operate nicely with as little as 9V for B+.
Westinghouse RA-DA - by Brad Winder - 09-09-2018, 10:41 PM
RE: Westinghouse RA-DA - by Arran - 09-10-2018, 03:04 AM
RE: Westinghouse RA-DA - by Chas - 09-10-2018, 08:54 AM
RE: Westinghouse RA-DA - by Phlogiston - 09-10-2018, 04:03 PM
RE: Westinghouse RA-DA - by Brad Winder - 09-18-2018, 08:32 AM
RE: Westinghouse RA-DA - by Phlogiston - 09-18-2018, 12:34 PM
RE: Westinghouse RA-DA - by Arran - 09-18-2018, 03:36 PM
There are currently 10036 online users. [Complete List]
» 2 Member(s) | 10034 Guest(s)
