37-116 Mag Tuning question
7estatdef Wrote:I've had one for close to 30yrs now that I got at an auction for $35. When I got it I replaced all the caps and such and it work great. About 10yrs ago it died and I'm thinking about putting her up on the bench and seeing what the matter is. I have a simple question. Does the mag tuning operate on the BC band only or will it act as an afc circuit on SW?
Tnx
Going the pickup a 37-675 tomorrow!! Tnx to Pete in NJ
Works on all bands. See the Magnetic Tuning info from my site:
PHILCO SERVICE HINTS & TIPS - NUMBER 33
Aligning the Magnetic Tuning System
http://www.philcorepairbench.com/tips/svctip33.htm
Chuck
37-116 Mag Tuning question - by 7estatdef - 08-22-2010, 09:14 PM
Re: 37-116 Mag Tuning question - by Sean - 08-22-2010, 09:37 PM
Re: 37-116 Mag Tuning question - by Chuck Schwark - 08-23-2010, 10:14 AM
