Ron's RCA T7-5 Cabinet Rescue
I have had good results with applying titebond glue to both the cabinet and the new veneer.
 let it dry and then iron it on. It worked quite well with a new top.
 here are some photos Of the one I did .
    Dan in Calgary
   Living in Calgary Alberta
Ron's RCA T7-5 Cabinet Rescue - by Ron Ramirez - 08-26-2018, 07:57 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by KCMike - 09-11-2018, 12:28 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by PhilcoJohn - 09-11-2018, 07:32 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Arran - 09-12-2018, 03:07 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by Dan Walker - 09-12-2018, 10:19 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by Eliot Ness - 09-16-2018, 07:08 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Arran - 09-18-2018, 03:38 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Arran - 09-21-2018, 03:49 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by KCMike - 09-23-2018, 03:17 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by klondike98 - 09-23-2018, 06:30 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Arran - 09-24-2018, 04:08 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by klondike98 - 09-24-2018, 05:18 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Arran - 09-25-2018, 12:24 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by KCMike - 10-02-2018, 07:48 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by EdHolland - 10-03-2018, 07:01 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by EdHolland - 10-07-2018, 10:13 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by morzh - 10-08-2018, 08:43 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by klondike98 - 10-17-2018, 10:13 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by morzh - 10-17-2018, 10:42 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Eliot Ness - 10-18-2018, 11:25 AM
RE: Ron's RCA T7-5 Cabinet Rescue - by tbone - 10-18-2018, 04:57 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by KCMike - 10-18-2018, 05:35 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by EdHolland - 10-18-2018, 07:59 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by PhilcoJohn - 10-19-2018, 06:57 PM
RE: Ron's RCA T7-5 Cabinet Rescue - by Joe Rossi - 10-31-2018, 10:05 PM
Users browsing this thread: 13 Guest(s)
