Eico 324 RF Output cable
It probably used a shielded (not coax) cable with an Amphenol connector, basically like and old fashioned microphone. There are available, at least NOS and used ones are, look it up on fleabay, or on Mouser or Digikey's sites.
Eico 324 RF Output cable - by Greggshere - 09-15-2018, 01:37 AM
RE: Eico 324 RF Output cable - by Arran - 09-15-2018, 03:44 AM
RE: Eico 324 RF Output cable - by Radioroslyn - 09-15-2018, 08:10 AM
RE: Eico 324 RF Output cable - by Greggshere - 09-15-2018, 10:19 AM
