zenith 12s568 issue
Hi guy's,
Terry was right on.
Pulled the tubes one at a time and found a bad 6K7 tube.
I know it tested ok before.
Pulled the 6J5's first, and got lucky on the 5th tube.
Thanks for the help again guy's.
murf
zenith 12s568 issue - by murf - 09-16-2018, 03:38 PM
RE: zenith 12s568 issue - by murf - 09-16-2018, 04:05 PM
RE: zenith 12s568 issue - by Radioroslyn - 09-16-2018, 04:51 PM
RE: zenith 12s568 issue - by murf - 09-16-2018, 09:32 PM
RE: zenith 12s568 issue - by morzh - 09-16-2018, 10:10 PM
RE: zenith 12s568 issue - by murf - 09-17-2018, 04:28 PM
There are currently 10198 online users. [Complete List]
» 3 Member(s) | 10195 Guest(s)
