-11 vdc at point j ?
guys, checked my speaker field coil out and sure enough, not good, one pin was almost 4k ohms. the green wires are in the
correct position and the black should be on the other side of the 500k resistor. as you have guessed my tube theory is 0
so now to find a usable field coil, A.E.S. I guess. but still my - dc must go. thanks again.
Don
-11 vdc at point j ? - by don hinkley - 09-17-2018, 01:11 PM
RE: -11 vdc at point j ? - by morzh - 09-17-2018, 02:05 PM
RE: -11 vdc at point j ? - by Radioroslyn - 09-17-2018, 03:45 PM
RE: -11 vdc at point j ? - by don hinkley - 09-17-2018, 07:05 PM
RE: -11 vdc at point j ? - by Radioroslyn - 09-17-2018, 07:35 PM
91H Code 126 Restore
