-11 vdc at point j ?
Opps I made a boo boo.
Did a little research on the G spkr to find that  the coil is abt 3.2K. So your is probably ok.
Unfortunately the schematic is somewhat difficult to read, lots of wire crossing over each other
but can't tell if they are connected or not.
Is the screen grid voltage on the 24a's ok??
-11 vdc at point j ? - by don hinkley - 09-17-2018, 01:11 PM
RE: -11 vdc at point j ? - by morzh - 09-17-2018, 02:05 PM
RE: -11 vdc at point j ? - by Radioroslyn - 09-17-2018, 03:45 PM
RE: -11 vdc at point j ? - by don hinkley - 09-17-2018, 07:05 PM
RE: -11 vdc at point j ? - by Radioroslyn - 09-17-2018, 07:35 PM
91H Code 126 Restore
