37-610 Speaker Wiring Replacement
mrphilco Wrote:Hi Gary
I know someone in the r.a.r+p newsgroup has already answered this for you, but 18 or even 20 gauge would be quite sufficient for what you're doing. If you wanted to use the repro cloth-covered wire from Radio Daze, you could get a piece of green, a piece of white, and a piece of blue, and be almost authentic. I've used 20 gauge cloth-covered wire for speakers in the past and never had an issue with them. I'm out of the stuff now, though, else I would send you three wires, sorry.
If you don't go the cloth-covered route, plastic insulated wire of 18 or 20 gauge will serve the purpose.
Thanks Ron. Authenticity is cool, but for now I want something that will do the job and look neat as well. I'm sort of anxious to get this set going, had it quite awhile and just realized without doing this it's a fire hazard to say the least.
73 de,
Gary/N9VU
37-610 Speaker Wiring Replacement - by n9vu - 02-03-2006, 12:21 AM
[No subject] - by Ron Ramirez - 02-05-2006, 10:27 AM
[No subject] - by n9vu - 02-05-2006, 01:21 PM
Eico 232 VTVM Schematic
There are currently 8836 online users. [Complete List]
» 1 Member(s) | 8835 Guest(s)
