Working on Philco Model 37-623-J
Hi all,
Can anyone tell me where the Battery leads go to each tube on this radio? The Schematic is not very clear.
RE: Working on Philco Model 37-623-J - by KCMike - 05-16-2018, 11:24 AM
RE: Working on Philco Model 37-623-J - by Radiofanatic - 09-26-2018, 01:26 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4990 online users. [Complete List]
» 3 Member(s) | 4987 Guest(s)
