*COMPLETED* simple S meter? for a minerva tropic master
well,,
my plan to gut a cheapy analog meter isnt acceptable.
first off it WILL WORK to use the pieces parts from a cheap analong meter but i dont actually like where it was taking me as far as bulk of parts.
so........ i continue my hunt for something in one box that will do the job
im just looin around right now.. i have no clue how to integrate a real s-meter but im sure theres nothing to it.
so far................
i really like this one,, its small like i want..
https://www.ebay.com/itm/CB-Radio-S-Mete...0752.m1982
this one is kinda big but still much smaller than regular power /switch gear panel mounted ones.
https://www.ebay.com/itm/REPLACEMENT-S-M...5313!US!-1
another tiny one
https://www.ebay.com/itm/WATKINS-JOHNSON...SwS4Nbpzfs
this one's discoloration will kinda match my glass,, slighly yellow"ish"
https://www.ebay.com/itm/ICOM-IC-271-IC-...SwE8VbptWq
still plugin away on this..
There are currently 10362 online users. [Complete List]
» 3 Member(s) | 10359 Guest(s)
