My RCA 18T
Hi Paul, we didn't get too much rain from Florence, and just some breeze, no strong wind. The past 2 days we have gotten more rain from a regular weather system than we did from the remnants of Florence. Today I replaced the last of the paper type condensers, all except for one, which is buried under the band switch. I don't want to f**k things up by trying to replace it, so I'm going to leave well enough alone until I see how the radio works when I install the last resistor, which is a 5 watt 12K carbon resistor. I'm using a 10 watt ceramic covered wire wound resistor for that. It should be here on Saturday.
My RCA 18T - by mikethedruid - 09-26-2018, 07:09 PM
RE: My RCA 18T - by Chas - 09-26-2018, 07:49 PM
RE: My RCA 18T - by Paul Philco322 - 09-26-2018, 08:49 PM
RE: My RCA 18T - by mikethedruid - 09-26-2018, 08:57 PM
RE: My RCA 18T - by mikethedruid - 09-27-2018, 07:10 PM
RE: My RCA 18T - by Ron Ramirez - 09-27-2018, 07:56 PM
RE: My RCA 18T - by mikethedruid - 11-28-2018, 10:55 PM
RE: My RCA 18T - by Brad Winder - 11-29-2018, 11:18 AM
RE: My RCA 18T - by EdHolland - 11-29-2018, 05:54 PM
RE: My RCA 18T - by Ron Ramirez - 11-29-2018, 08:01 PM
RE: My RCA 18T - by Paul Philco322 - 11-29-2018, 10:09 PM
RE: My RCA 18T - by mikethedruid - 11-29-2018, 10:39 PM
RE: My RCA 18T - by Paul Philco322 - 11-29-2018, 10:47 PM
RE: My RCA 18T - by mikethedruid - 11-30-2018, 07:27 PM
RE: My RCA 18T - by Paul Philco322 - 11-30-2018, 11:56 PM
There are currently 10444 online users. [Complete List]
» 2 Member(s) | 10442 Guest(s)
