Kiwi 46-816?
Yes pretty much the same way. You could simply take an alignment procedure for any radio with SW band(s) similar to yours and see what they do, but simple feeding the frequencies and adjustings trimmer/padder will do.
If the generator is not capable of producing the frequency high enough, tuning to harmonics works too (say, using 7MHz for 14MHz/21MHz).
Transoceanic uses points in the middle of the scale. But the idea is the same.
Kiwi 46-816? - by ashhhhh - 09-27-2018, 01:58 AM
RE: Kiwi 46-816? - by morzh - 09-27-2018, 08:04 AM
RE: Kiwi 46-816? - by ashhhhh - 09-27-2018, 07:39 PM
RE: Kiwi 46-816? - by morzh - 09-27-2018, 09:52 PM
RE: Kiwi 46-816? - by ashhhhh - 09-28-2018, 02:00 AM
RE: Kiwi 46-816? - by ashhhhh - 09-28-2018, 06:13 AM
RE: Kiwi 46-816? - by morzh - 09-28-2018, 07:40 AM
91H Code 126 Restore
There are currently 5103 online users. [Complete List]
» 1 Member(s) | 5102 Guest(s)
