Wood Type Question
Thanks Doug. I was guessing it was probably ebony. I appreciate the refinishing tips too.
Derek
Wood Type Question - by Derek D - 01-24-2006, 01:31 PM
wood types - by Doug Houston - 01-24-2006, 07:47 PM
[No subject] - by Derek D - 02-06-2006, 11:24 AM
