NOOBY - Philco Model 76 Schematic Question
Hello, I am new to tube radio restoration, but not to electronics. I recently acquired a Philco 76 Lowbay (Early Version). I have found the schematic on-line and have a question. All over the schematic are numbers in circles with an arrow pointing at various component components. What are the meaning of these numbers in circles?
Frank
NOOBY - Philco Model 76 Schematic Question - by Guest - 09-01-2010, 06:50 PM
Re: NOOBY - Philco Model 76 Schematic Question - by Guest - 09-02-2010, 08:03 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
