Philco 116 repro dial scale
Any comments offered for the reproduction Philco 116 dial scale as sold by Radio Daze? Is the plastic clear enough for the dial lamps to shine through? Are there better repros available?
Philco 116 repro dial scale - by don'tdomelikethat - 09-05-2010, 02:23 PM
Re: Philco 116 repro dial scale - by Ron Ramirez - 09-05-2010, 02:48 PM
There are currently 9686 online users. [Complete List]
» 1 Member(s) | 9685 Guest(s)
