8G005 Zenith T/O Restoration
It's not bad even now, in my basement, with no antenna at all. I'm sure with the rod or the loop it's going to be even better.
8G005 Zenith T/O Restoration - by morzh - 09-01-2018, 07:26 PM
RE: 8G005 Zenith T/O Restoration - by klondike98 - 09-02-2018, 09:08 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-02-2018, 11:12 PM
RE: 8G005 Zenith T/O Restoration - by Arran - 09-03-2018, 02:37 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-03-2018, 05:10 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-10-2018, 09:05 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-24-2018, 10:56 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 09-30-2018, 09:21 PM
RE: 8G005 Zenith T/O Restoration - by PhilcoJohn - 10-01-2018, 07:50 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-01-2018, 08:05 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-01-2018, 10:28 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-02-2018, 08:20 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-02-2018, 08:34 PM
RE: 8G005 Zenith T/O Restoration - by KCMike - 10-02-2018, 09:27 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-02-2018, 10:06 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-03-2018, 08:06 PM
RE: 8G005 Zenith T/O Restoration - by sam - 10-03-2018, 10:53 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-03-2018, 11:01 PM
RE: 8G005 Zenith T/O Restoration - by sam - 10-03-2018, 11:19 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-03-2018, 11:34 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-04-2018, 03:41 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-04-2018, 07:58 PM
RE: 8G005 Zenith T/O Restoration - by klondike98 - 10-04-2018, 09:54 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-04-2018, 10:34 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 10-05-2018, 10:10 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 11-29-2018, 10:01 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 12-08-2018, 07:34 PM
RE: 8G005 Zenith T/O Restoration - by morzh - 12-08-2018, 08:44 PM
RE: 8G005 Zenith T/O Restoration - by klondike98 - 12-09-2018, 11:12 AM
RE: 8G005 Zenith T/O Restoration - by morzh - 12-09-2018, 11:39 AM
There are currently 10246 online users. [Complete List]
» 3 Member(s) | 10243 Guest(s)
