Big-Dirty 47-1230 Electronics Restoration
>I know these values are a little off
A couple of thoughts. Could have a replacement power transformer that is a bit lower in output voltage, weak 5Y3, or something is loading the power supply down. In any event the hv voltage are still are within 10% of where they should and that's good enough to do some troubleshooting.
I wouldn't condemn any of the tubes so far as for the most part a weak tube will still work short of the heater being burned out.
RE: Big-Dirty 47-1230 Electronics Restoration - by Radioroslyn - 10-04-2018, 11:28 PM
91H Code 126 Restore
There are currently 3225 online users. [Complete List]
» 1 Member(s) | 3224 Guest(s)
