Model 80 BB gun indentation, how to fill??
It looks like some of the wood has been lost. So more steam probably won't help. Use mahogany wood filler - or walnut or a mix of both. Mahogany is usually too light and walnut too dark. TOO DARK usually looks better than too light.
RE: Model 80 BB gun indentation, how to fill?? - by Phlogiston - 10-06-2018, 05:18 PM
