Early 20 at our local swap meet
This type chassis with its very characteristic look was used in those radios that came before 20, including their first superhet, the 111/112.
The 20 had smaller chassis that was the first Baby-grand and would fit in a cathedral tabletop. The previous one would not; the only tabletop it would fit into was a 511.
Let alone the fact that the dial in all of these was the rotating cylinder with the surface facing the operator and so the numbers moved up-down, while in the 20 it was a circular sector type and the numbers moved left-right.
Another tell-tell sign also is the tube shield.
And, of course, the face with the knobs widely spaced in the 85 and such, vs the small triangle in the 20.
Early 20 at our local swap meet - by OldRestorer - 10-07-2018, 12:04 PM
RE: Early 20 at our local swap meet - by morzh - 10-07-2018, 01:33 PM
RE: Early 20 at our local swap meet - by morzh - 10-08-2018, 12:00 PM
RE: Early 20 at our local swap meet - by Arran - 10-09-2018, 03:18 AM
91H Code 126 Restore
There are currently 3209 online users. [Complete List]
» 2 Member(s) | 3207 Guest(s)
