Low volume on Belmont Model 6D111
OH NO!!!!!!!!!!!!!!!!!!!!!!!!!!
You found me!!
Ok so disconnect the lead coming from C-15 to the wiper of the volume control . Turn set on and touch the disconnected wire (connected to c-15). Should buzz and the level of buzz is going to be the loudest the set will play. Does it buzz loudly?? I'm not all together sure if an audio amp problem but it's a good place to start troubleshooting. All of the noted voltages look good.
RE: Low volume on Belmont Model 6D111 - by Radioroslyn - 10-08-2018, 12:50 PM
