Low volume on Belmont Model 6D111
No those are the correct values, Terry. Just double checked. Do you think that the missing load coil that was attached to the missing original loop antenna could be critical? I'm wondering if not having the original antenna can be causing this low volume? Or would a problem in the output if coil cause this? Or even the output transformer (even though it ohms out) ?
RE: Low volume on Belmont Model 6D111 - by NostalgiaRadioTime - 10-08-2018, 08:55 PM
There are currently 8802 online users. [Complete List]
» 3 Member(s) | 8799 Guest(s)
