*COMPLETED* simple S meter? for a minerva tropic master
i am moving on to another post here, about integrating a home brew simple BFO. i have notes i took about how to but too much time has passed and i am having trouble interpreting the notes.
this Smeter is working pretty good though so i will likely duplicate it on other sets.
There are currently 10347 online users. [Complete List]
» 3 Member(s) | 10344 Guest(s)
