46-350 hinged back?
Have any of you seen a Philco 46-350 with a hinged back? This one is hardboard, so I suspect it is a nice-quality modification:
[Image: http://i269.photobucket.com/albums/jj77/...hinges.jpg]
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
46-350 hinged back? - by FStephenMasek - 09-09-2010, 09:41 PM
Re: 46-350 hinged back? - by Ron Ramirez - 09-09-2010, 09:52 PM
There are currently 8291 online users. [Complete List]
» 5 Member(s) | 8286 Guest(s)
AvatarAvatarAvatarAvatar
