Inverter specs needed?
The 66B and the 37-610 are both 60 watt sets.  The 620 consumes 65 watts.   I would think an inverter that handled three hundred watts should do the job but I have no idea what the effect of that has on your battery drain since I don't have one of these but based on some info I found online ( https://www.donrowe.com/power-inverter-faq-a/258.htm ) you probably want to keep the motor running for at least some of that 2 hours.
Inverter specs needed? - by PhilcoPhan1936 - 10-14-2018, 04:17 PM
RE: Inverter specs needed? - by klondike98 - 10-14-2018, 04:39 PM
RE: Inverter specs needed? - by morzh - 10-14-2018, 04:41 PM
RE: Inverter specs needed? - by Phlogiston - 10-14-2018, 04:42 PM
RE: Inverter specs needed? - by PhilcoPhan1936 - 10-14-2018, 05:06 PM
RE: Inverter specs needed? - by Chas - 10-14-2018, 09:02 PM
The speaker table error?
Philco 70 antenna lead
