Radiola Senior
Seems like a good price! Earlier models have a wood front (top) panel and the later are bakelite. #30 toob is a good mod as they are much cheaper and won't kill your A battery like a WD-11 (250ma vs 60ma) Come to think of it I don't know if a globe toob would fit? Take a quick look it the socket does it have 3 small holes and one larger one? If so start looking for a WD-11. Check out Bill Turner site he reproduces a WD-11 using a test tube and a 5676 pencil toob.
ps Your's is the later version.
Radiola Senior - by Jayce - 09-11-2010, 10:09 PM
Re: Radiola Senior - by 7estatdef - 09-12-2010, 07:31 AM
Re: Radiola Senior - by Ron Ramirez - 09-12-2010, 07:44 AM
Re: Radiola Senior - by Jayce - 09-12-2010, 12:00 PM
Re: Radiola Senior - by Alan Douglas - 09-14-2010, 12:17 PM
Re: Radiola Senior - by Jayce - 09-14-2010, 09:54 PM
Re: Radiola Senior - by Alan Douglas - 09-14-2010, 10:39 PM
Re: Radiola Senior - by Jayce - 09-21-2010, 10:34 PM
Re: Radiola Senior - by Arran - 10-13-2010, 11:11 PM
Re: Radiola Senior - by Alan Douglas - 10-15-2010, 09:44 PM
There are currently 9704 online users. [Complete List]
» 1 Member(s) | 9703 Guest(s)
