40-158 Veneer question- Updated-Finished!
For decals, you will get the best results if you apply decals after toner and before you begin to spray the clear lacquer. If you apply the decals after you've applied a few coats of clear lacquer, the cut lines of the decals will always show unless you then apply a lot more coats of clear, and you really don't want to do that.
RE: 40-158 Veneer question - by Radioroslyn - 09-01-2018, 09:38 PM
RE: 40-158 Veneer question - by Greggshere - 09-01-2018, 09:53 PM
RE: 40-158 Veneer question - by Radioroslyn - 09-01-2018, 10:16 PM
RE: 40-158 Veneer question - by Greggshere - 09-01-2018, 10:41 PM
RE: 40-158 Veneer question - by Greggshere - 10-07-2018, 11:41 PM
RE: 40-158 Veneer question - by DadsRadio - 10-13-2018, 09:40 AM
RE: 40-158 Veneer question - by klondike98 - 10-13-2018, 07:18 PM
RE: 40-158 Veneer question - by DadsRadio - 10-15-2018, 07:29 PM
RE: 40-158 Veneer question - by Radioroslyn - 10-16-2018, 11:46 PM
RE: 40-158 Veneer question - by Greggshere - 10-17-2018, 12:19 AM
RE: 40-158 Veneer question - by Ron Ramirez - 10-17-2018, 05:56 AM
RE: 40-158 Veneer question - by Greggshere - 10-17-2018, 10:52 AM
RE: 40-158 Veneer question - by Ron Ramirez - 10-17-2018, 11:44 AM
RE: 40-158 Veneer question - by Greggshere - 10-17-2018, 12:51 PM
RE: 40-158 Veneer question - by Greggshere - 10-21-2018, 12:04 AM
RE: 40-158 Veneer question - by klondike98 - 10-21-2018, 09:32 AM
RE: 40-158 Veneer question - by DadsRadio - 10-25-2018, 01:57 PM
RE: 40-158 Veneer question - by Greggshere - 10-26-2018, 05:03 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 4882 online users. [Complete List]
» 1 Member(s) | 4881 Guest(s)
