Stromberg Carlson AWP-8
Wave Wizard antenna.
This thing is 10 years younger than the 8G005 and 14 years vs 7G605, so it has lots of new stuff....like miniature tubes and drum band switch, like in TVs.
That screw (two at both sides) keeps the chassis from sliding out.
What I did not appreciate was that the chassis is taken out from the front, not from the back.
Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:04 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 07:07 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:21 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 07:28 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:31 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 09:01 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-17-2018, 09:13 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 10:39 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 10:53 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 10:56 PM
RE: Stromberg Carlson AWP-8 - by Chas - 10-18-2018, 08:41 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 09:09 AM
RE: Stromberg Carlson AWP-8 - by Radioroslyn - 10-18-2018, 09:18 AM
RE: Stromberg Carlson AWP-8 - by EdHolland - 10-18-2018, 12:25 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 03:49 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-18-2018, 04:36 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 04:42 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-18-2018, 04:51 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 04:54 PM
RE: Stromberg Carlson AWP-8 - by EdHolland - 10-18-2018, 08:09 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 09:48 PM
RE: Stromberg Carlson AWP-8 - by Eliot Ness - 10-19-2018, 08:26 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 09:13 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 09:19 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 10:05 PM
RE: Stromberg Carlson AWP-8 - by kj0002 - 10-20-2018, 09:57 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-21-2018, 12:34 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-27-2018, 07:40 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 07:49 AM
RE: Stromberg Carlson AWP-8 - by Eliot Ness - 10-30-2018, 11:03 AM
RE: Stromberg Carlson AWP-8 - by Paul Philco322 - 10-30-2018, 11:09 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 01:57 PM
RE: Stromberg Carlson AWP-8 - by WyTex - 10-30-2018, 02:20 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 03:56 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 08:05 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-03-2018, 07:21 PM
RE: Stromberg Carlson AWP-8 - by Paul Philco322 - 11-03-2018, 07:57 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-04-2018, 01:39 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-04-2018, 08:04 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-11-2018, 06:24 PM
RE: Stromberg Carlson AWP-8 - by klondike98 - 11-11-2018, 07:09 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-11-2018, 08:08 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-23-2018, 01:18 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-26-2018, 03:54 PM
RE: Stromberg Carlson AWP-8 - by WyTex - 11-27-2018, 10:02 AM
RE: Stromberg Carlson AWP-8 - by morzh - 11-27-2018, 02:45 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-28-2018, 04:32 PM
RE: Stromberg Carlson AWP-8 - by morzh - 12-08-2018, 08:46 PM
There are currently 10107 online users. [Complete List]
» 2 Member(s) | 10105 Guest(s)
