Stromberg Carlson AWP-8
I didn't know you could sing! Nice wig too. [Image: http://philcoradio.com/phorum/images/smi...on_lol.gif]
The Halli S72 is a pretty straightforward set and doesn't use the 1L6 tube, uses 2 1R5's.
The RCA Strat does use a 1L6 and God help you if the dial cord needs to be replaced.
Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:04 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 07:07 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:21 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 07:28 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 07:31 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 09:01 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-17-2018, 09:13 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 10:39 PM
RE: Stromberg Carlson AWP-8 - by sam - 10-17-2018, 10:53 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-17-2018, 10:56 PM
RE: Stromberg Carlson AWP-8 - by Chas - 10-18-2018, 08:41 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 09:09 AM
RE: Stromberg Carlson AWP-8 - by Radioroslyn - 10-18-2018, 09:18 AM
RE: Stromberg Carlson AWP-8 - by EdHolland - 10-18-2018, 12:25 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 03:49 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-18-2018, 04:36 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 04:42 PM
RE: Stromberg Carlson AWP-8 - by KCMike - 10-18-2018, 04:51 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 04:54 PM
RE: Stromberg Carlson AWP-8 - by EdHolland - 10-18-2018, 08:09 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-18-2018, 09:48 PM
RE: Stromberg Carlson AWP-8 - by Eliot Ness - 10-19-2018, 08:26 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 09:13 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 09:19 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-19-2018, 10:05 PM
RE: Stromberg Carlson AWP-8 - by kj0002 - 10-20-2018, 09:57 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-21-2018, 12:34 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-27-2018, 07:40 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 07:49 AM
RE: Stromberg Carlson AWP-8 - by Eliot Ness - 10-30-2018, 11:03 AM
RE: Stromberg Carlson AWP-8 - by Paul Philco322 - 10-30-2018, 11:09 AM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 01:57 PM
RE: Stromberg Carlson AWP-8 - by WyTex - 10-30-2018, 02:20 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 03:56 PM
RE: Stromberg Carlson AWP-8 - by morzh - 10-30-2018, 08:05 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-03-2018, 07:21 PM
RE: Stromberg Carlson AWP-8 - by Paul Philco322 - 11-03-2018, 07:57 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-04-2018, 01:39 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-04-2018, 08:04 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-11-2018, 06:24 PM
RE: Stromberg Carlson AWP-8 - by klondike98 - 11-11-2018, 07:09 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-11-2018, 08:08 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-23-2018, 01:18 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-26-2018, 03:54 PM
RE: Stromberg Carlson AWP-8 - by WyTex - 11-27-2018, 10:02 AM
RE: Stromberg Carlson AWP-8 - by morzh - 11-27-2018, 02:45 PM
RE: Stromberg Carlson AWP-8 - by morzh - 11-28-2018, 04:32 PM
RE: Stromberg Carlson AWP-8 - by morzh - 12-08-2018, 08:46 PM
There are currently 8621 online users. [Complete List]
» 3 Member(s) | 8618 Guest(s)
