AA5 hum
This one?
http://www.nostalgiaair.org/pagesbymodel...003170.pdf
Check the 50C5 for heater/cathode leakage and the 12BE6 too.
If the pressed copper loop got wet (cleaned) or the radio was once stored in a damp location. Place the loop in an oven 150F or so for a couple of hours. Check all the loop winding's for continuity. If the set got a polarized cord, change back to a parallel, that will allow the cord to be reversed to explore the AC line as an RF return.
If the chassis shows even the slightest corrosion and has riveted grounding lugs or lugs on tube socket rings, solder those to the chassis with a high wattage iron to get good wetting of solder.
Do look for devices on the AC power line as a source of hum as Terry suggested. The consider an alignment to bring up the sensitivity. Local noise can cause the AVC to cut back the IF gain...
Most is moot if the home is covered in stucco, brick, stone, aluminum siding or foil vapor barrier, radio in the cellar or surrounded by high rise buildings...
It appears this radio has the troublesome IF cans, well, if the set is working without crashing noises the IF cans will be O.K. for a while longer.
Oh, C16's, the filters, are connected to B- not the chassis...
YMMV
Chas
Pliny the younger
AA5 hum - by fenbach - 10-18-2018, 11:02 PM
RE: AA5 hum - by Radioroslyn - 10-18-2018, 11:28 PM
RE: AA5 hum - by Jayce - 10-19-2018, 12:05 AM
RE: AA5 hum - by Chas - 10-19-2018, 12:09 AM
RE: AA5 hum - by fenbach - 10-19-2018, 08:18 PM
RE: AA5 hum - by fenbach - 10-19-2018, 08:20 PM
RE: AA5 hum - by Chas - 10-20-2018, 12:04 AM
RE: AA5 hum - by gregb - 10-21-2018, 12:04 AM
RE: AA5 hum - by David - 11-04-2018, 03:20 PM
RE: AA5 hum - by Jayce - 11-04-2018, 09:24 PM
RE: AA5 hum - by 35Z5 - 11-05-2018, 09:57 AM
RE: AA5 hum - by morzh - 11-05-2018, 10:48 AM
RE: AA5 hum - by Squire - 11-08-2018, 01:12 AM
RE: AA5 hum - by fenbach - 03-16-2019, 11:12 PM
RE: AA5 hum - by Arran - 03-16-2019, 11:49 PM
RE: AA5 hum - by 35Z5 - 03-17-2019, 05:55 PM
RE: AA5 hum - by fenbach - 03-23-2019, 07:54 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2536 online users. [Complete List]
» 2 Member(s) | 2534 Guest(s)
