Radiola Senior
I pulled my Radiola apart today and it might need a little work to get going. One wire is broken and it is that stuff that seems to have wire strands interwoven through the fabric instead of a core of strands like later wire. Also, there is a flat block between the earphone connectors that looks a little crappy with corrosion. Other than those two things, it looks good inside. One oddity, I pulled half of an Aeriola Senior tag that was crumpled in the bottom of the case. Why was that in there? The half that is intact is a help though as it shows how to properly connect the batteries. After taping it back together, I scanned the fragile piece into my computer.
Radiola Senior - by Jayce - 09-11-2010, 10:09 PM
Re: Radiola Senior - by 7estatdef - 09-12-2010, 07:31 AM
Re: Radiola Senior - by Ron Ramirez - 09-12-2010, 07:44 AM
Re: Radiola Senior - by Jayce - 09-12-2010, 12:00 PM
Re: Radiola Senior - by Alan Douglas - 09-14-2010, 12:17 PM
Re: Radiola Senior - by Jayce - 09-14-2010, 09:54 PM
Re: Radiola Senior - by Alan Douglas - 09-14-2010, 10:39 PM
Re: Radiola Senior - by Jayce - 09-21-2010, 10:34 PM
Re: Radiola Senior - by Arran - 10-13-2010, 11:11 PM
Re: Radiola Senior - by Alan Douglas - 10-15-2010, 09:44 PM
Philco 91 Tuning Condenser
