AA5 hum
I just repaired an AA5 set for a customer yesterday and it had rather weak reception and I have seen this problem before. There is a low value capacitor, approx. 100pf, in the grid circuit of the convertor tube and it had gone bad. I have had three sets now that had poor reception after a recap and changing that cap brings it back to life. They are usually a silver mica or a ceramic cap so are not normally changed in a rebuild. Might be worth a try in your case.
Gregb
AA5 hum - by fenbach - 10-18-2018, 11:02 PM
RE: AA5 hum - by Radioroslyn - 10-18-2018, 11:28 PM
RE: AA5 hum - by Jayce - 10-19-2018, 12:05 AM
RE: AA5 hum - by Chas - 10-19-2018, 12:09 AM
RE: AA5 hum - by fenbach - 10-19-2018, 08:18 PM
RE: AA5 hum - by fenbach - 10-19-2018, 08:20 PM
RE: AA5 hum - by Chas - 10-20-2018, 12:04 AM
RE: AA5 hum - by gregb - 10-21-2018, 12:04 AM
RE: AA5 hum - by David - 11-04-2018, 03:20 PM
RE: AA5 hum - by Jayce - 11-04-2018, 09:24 PM
RE: AA5 hum - by 35Z5 - 11-05-2018, 09:57 AM
RE: AA5 hum - by morzh - 11-05-2018, 10:48 AM
RE: AA5 hum - by Squire - 11-08-2018, 01:12 AM
RE: AA5 hum - by fenbach - 03-16-2019, 11:12 PM
RE: AA5 hum - by Arran - 03-16-2019, 11:49 PM
RE: AA5 hum - by 35Z5 - 03-17-2019, 05:55 PM
RE: AA5 hum - by fenbach - 03-23-2019, 07:54 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2484 online users. [Complete List]
» 5 Member(s) | 2479 Guest(s)
AvatarAvatarAvatarAvatar
