41-616 restoration
Philco, like any other manufacturer, used parts such as that candohm for a reason, if they could have used half Watt resistors in it's place they would have since they are cheaper. I would guess that the resistors in the candohm are at least 3 Watts if not larger, but 5 and 10 Watters are cheap enough to use as replacements, and offer a little more headroom. You also have to remember that the candohm was using the chassis as a heat sink, so if you use free standing resistors it would be wise to use ones of a higher Wattage, for the larger Wattage ones you could go chassis mount like those gold and black ones with the aluminum body.
41-616 restoration - by 78zenithtv - 10-20-2017, 01:42 AM
RE: 41-616 restoration - by 78zenithtv - 10-20-2017, 09:19 AM
RE: 41-616 restoration - by Ron Ramirez - 10-21-2017, 07:10 AM
RE: 41-616 restoration - by klondike98 - 10-21-2017, 02:00 PM
RE: 41-616 restoration - by 78zenithtv - 10-21-2017, 02:20 PM
RE: 41-616 restoration - by Ron Ramirez - 10-25-2017, 06:10 AM
RE: 41-616 restoration - by 78zenithtv - 10-24-2018, 10:06 AM
RE: 41-616 restoration - by Arran - 10-24-2018, 09:20 PM
RE: 41-616 restoration - by 78zenithtv - 10-28-2018, 05:01 PM
RE: 41-616 restoration - by 78zenithtv - 10-28-2018, 05:02 PM
RE: 41-616 restoration - by klondike98 - 10-29-2018, 10:41 AM
RE: 41-616 restoration - by 78zenithtv - 10-29-2018, 12:58 PM
RE: 41-616 restoration - by Steve Davis - 10-29-2018, 02:23 PM
RE: 41-616 restoration - by klondike98 - 10-29-2018, 04:21 PM
41-616 restoration - by klondike98 - 10-20-2017, 08:24 AM
91H Code 126 Restore
