type of veneer?
thanks so much for your reply. the radio I have is a rectangle not the curved sides. the top and sides are a light blond looking wood. I only have to veneer the top if I can match it. the front I will do in walnut maybe or try to duplicate the faux as close as possible. thanks again. John.
type of veneer? - by flymobro - 09-15-2010, 06:04 AM
Re: type of veneer? - by Ron Ramirez - 09-15-2010, 11:20 AM
Re: type of veneer? - by flymobro - 09-15-2010, 06:08 PM
There are currently 9659 online users. [Complete List]
» 1 Member(s) | 9658 Guest(s)
