10-26-2018, 03:14 PM
My 6A7 and a few other tubes arrived today from Bob D's FindATube so I was all set to fire the 66B up and get it aligned...ho ho ho
Getting past the dim bulb test OK I powered it up at about 115v. The 80 filament lit as did the dial lamp but the set was ominously quiet! I flipped the tone switch and did hear a small click through the speaker and a screwdriver on the cap of 75 produced a buzzing through the speaker so at least the audio seems to work. Voltages on the tubes were as follows:
[Image: https://www.dropbox.com/s/qeoad4s7k6uzv4....jpg?raw=1]
Voltages on the electrolytics were:
Electrolytic Cap#50 (red lug)= 293v
Electrolytic Cap#50 (plain lug)= 350v
Electrolytic Cap#49 = 0v
Gotta be the choke #48... and indeed when I checked it (I swear I checked it earlier
) it is open. Its a bit of a tight fit where its located so I'll have to see what I can find to replace it. I don't have a spec on it but following Terry's previous advice on an open filter choke is go with the highest Henrys that fit the physical dimensions for the choke. More later...
