Philco Jr. 80
Thanks guys.  A painted chassis certainly is not like original but it looks good to the average person.  This set is not a collectors item, so it's the average person that I'm appealing to in my minimal collection.
I'm thinking that judicious plate bending on the tuning cap will help with the sensitivity across the band.
Philco Jr. 80 - by rfeenstra - 10-26-2018, 09:04 PM
RE: Philco Jr. 80 - by klondike98 - 10-26-2018, 09:20 PM
RE: Philco Jr. 80 - by Paul Philco322 - 10-26-2018, 09:30 PM
RE: Philco Jr. 80 - by rfeenstra - 10-26-2018, 10:03 PM
RE: Philco Jr. 80 - by claude.france - 10-27-2018, 07:26 AM
RE: Philco Jr. 80 - by rfeenstra - 10-27-2018, 12:54 PM
RE: Philco Jr. 80 - by Arran - 10-27-2018, 04:22 PM
RE: Philco Jr. 80 - by rfeenstra - 10-27-2018, 08:10 PM
RE: Philco Jr. 80 - by Greggshere - 11-01-2018, 09:41 AM
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Philco 91 Restore Code ??
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
So sometime  back I posted some photos of a badly damaged in transport T62, not the tank. I did manage to get a donor c...Paul Philco322 — 05:43 PM
There are currently 2772 online users. [Complete List]
» 2 Member(s) | 2770 Guest(s)
