Zenith 6-S-147 Chairside
Just acquired this set, and the compartment lid is missing. Does anyone have a close-up of the hinges, and the top of the lid? I'll need to make one and inlay the veneer.
[Image: http://i1367.photobucket.com/albums/r796...zcenyp.jpg]
Pat
Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 04:33 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 07:37 PM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-28-2018, 08:40 PM
RE: Zenith 6-S-147 Chairside - by Phlogiston - 10-28-2018, 09:18 PM
RE: Zenith 6-S-147 Chairside - by Arran - 10-29-2018, 03:55 AM
RE: Zenith 6-S-147 Chairside - by Patrick - 10-29-2018, 05:44 AM
RE: Zenith 6-S-147 Chairside - by Arran - 11-01-2018, 12:11 AM
There are currently 10426 online users. [Complete List]
» 1 Member(s) | 10425 Guest(s)
